installer doesn't work on mac os 10.6.8
opiuq
Post by opiuq »
Hi everybody,
I just downloaded the last demo (version 1.6.1.6) but the installer doesn't work on Mac OS 10.6.8 but works on 10.9.5...
The exact same file I downloaded and unzipped once! In the requirements page, there is no mention about a minimum OS.
Any clue?
Thank You in advance for the reply.
Re: installer doesn't work on mac os 10.6.8
I don't think 10.6 is supported anymore. Not the answer you are looking for, but I'll update the minimum requirements.
rocky1221
Post by rocky1221 »
I am also not being able to install as the installer is not working properly.
Apple dropped support for macOS versions older than 10.12.
There's a workaround that involves me reinstalling Catalina, but I won't do that until after I finish version 1.4. But even then, the lowest supported version will be 10.7.
