Plugin mode - exception in Mainstage.
patrik
Post by patrik »
Hi, i just upgraded both the firmware and the control application to the latest versions.
I get the following when I reset and rescan the plugin:
validating Audio Unit MIDI EXPRESSION by Audiofront:
AU Validation Tool
Version: 1.7.0
Copyright 2003-2019, Apple Inc. All Rights Reserved.
Specify -h (-help) for command options
VALIDATING AUDIO UNIT: 'aufx' - 'AFME' - 'AUFO'
Manufacturer String: Audiofront
AudioUnit Name: MIDI EXPRESSION
Component Version: 2.8.2 (0x20802)
* * PASS
TESTING OPEN TIMES:
COLD:
[Symbiosis](0x107543dc0) AU kComponentOpenSelect
[Audiofront: MIDI EXPRESSION](0x107543dc0) VST open
[Audiofront: MIDI EXPRESSION](0x107543dc0) VST audioMasterVersion
[Audiofront: MIDI EXPRESSION](0x107543dc0) VST audioMasterGetVendorString
[Audiofront: MIDI EXPRESSION](0x107543dc0) VST setSampleRate: 44100.000000
[Audiofront: MIDI EXPRESSION](0x107543dc0) VST setBlockSize: 4096
[Audiofront: MIDI EXPRESSION](0x107543dc0) VST setBypass: off
[Audiofront: MIDI EXPRESSION](0x107543dc0) VST getInputProperties: 0
[Audiofront: MIDI EXPRESSION](0x107543dc0) VST getOutputProperties: 0
[Audiofront: MIDI EXPRESSION](0x107543dc0) Caught Mac OS exception in SymbiosisEntry: Mac OS error code -5000
[Audiofront: MIDI EXPRESSION](0x107543dc0) AU kComponentCloseSelect
FATAL ERROR: OpenAComponent: result: -5000,0xFFFFEC78
validation result: couldn’t be opened
Re: Plugin mode - exception in Mainstage.
Looks like a permissions issue. Can you uninstall and reinstall? You'll probably need to reboot after reinstalling.
patrik
Post by patrik »
Thanx for fast feedback. I'll try that.
patrik
Post by patrik »
Reinstalling and rebooting did'nt help but since you suggested that it was a permission issue I went ahead and changed the permissions on the MIDI Expressions AU.component.
I changed the permissions from read only to read/write for the group "wheel".
After that it works fine so if you don't see any problems with that solution, I'm happy.
Thanks for pointing me in the right direction.
Cheers
/Patrik
I thought I resolved that issue, but I'll have to double check.
