DSP trigger with TD3 module.
overg
Post by overg »
I would like to buy your product as I understand that you can upgrade almost any kit for positional sensing and so on.
I have the following configuration and need some help to test your product before buying :
1) I have roland TD3 module, connected to mesh heads on acoustic kit, with DDRum triggers.
the module is connected to my computer, and I use addictive drums2.
I would like to know if it is possible to use your app as stand alone with addictive, so I can just enjoy the kit upgrade?
2) In case 1 is not possible, I use logic, and I open your software and addictive in logic, now that both of them are open, what do I need to do in order to test it ? ( is it even possible if it going through the roland TD3 midi?)
Thanks
Op
Re: DSP trigger with TD3 module.
Sorry for the late response. I don't think those DDrum triggers will allow for positional sensing. They are mounted on the shell of the drum right?
