Name inputs?
CodaClef
Name inputs?
Post by CodaClef »
Is there a way to name inputs?
Can we get the ability to do so in an upcoming build?
Maybe something like this???
Re: Name inputs?
No. But you can use drum maps to achieve the same result already.
CodaClef
Re: Name inputs?
Post by CodaClef »
Hmm, I can't figure out how to rename items?
I must be missing something obvious.
You mean here right?
Screenshot 2025-03-12 013450.png (149.35 KiB) Viewed 3202 times
Re: Name inputs?
You can't. You just can use the icons and the text associated with those images.
Re: Name inputs?
CodaClef
Re: Name inputs?
Post by CodaClef »
OK, I think I got it, so is that just a "dumb" map and you drag the input from the upper rectangular bar onto it???
CodaClef
Re: Name inputs?
Post by CodaClef »
yeah?
Re: Name inputs?
No, it's not like that. I think it's pretty intuitive, though. Just for fun, set some of your inputs to kit pieces and everything will become very clear.
