27mm vs 35mm Piezo?
Austin
27mm vs 35mm Piezo?
Post by Austin »
Hello! I'm doing an A2E conversion of some Yamaha Stage Custom 10" and 12" toms and have settled on UFOdrums for my triggers. My only question is if I should ask him to build it with 27mm center piezos instead of his usual 35mm piezos. I asked him and he said he switched to using 35mm piezos because most drummers preferred that but will make them with 27mm piezos if I request. Is that something that is recommended? I'm planning on getting his ebridge trigger for one tom and his side mount system for the other. Should I get 27mm piezos for the center and 35mm for the rim on both or just the one with the center mounted piezo? Thank you!
