New Roland Quiet Design support?
AndreaZanini
Contact:
Post by AndreaZanini »
Are there any plans to officially support the new silent design by Roland?
____
Andy
Re: New Roland Quiet Design support?
They are still piezo based, so shouldn't be a problem.
Might need to have a bit of gain boost to accommodate the weaker signal from the quieter pads.
If anyone has a quiet pad and quiet cymbal to send to Rob for a bit, I'm sure he can come up with a preset.
There's nothing particularly different about them, they are just designed to be acoustically quieter. They should work very well with eDRUMin.
