HiHat Level or CC Mode?
Anyone using CC mode for the hihat? Better articulation when using DAW settings for open and close, strikes zones, etc?
Re: HiHat Level or CC Mode?
I always use CC mode.
Thu Apr 18, 2024 9:19 pm
Thankx rob, goin for it 👍
The only reason why you might use hihat levels mode is if you're triggering on a Roland module, which means a separate notes for open and closed hihat hits, or some other application that doesn't support CCs.
