Preset recommendation for Lemon 13” x 5” Mesh Black Sparkle Snare for Roland
Forum rules
kenmarcou
Post by kenmarcou »
Hi! I got the Lemon 13” x 5” Mesh Black Sparkle Snare for Roland. Center piezo. I was wondering if anyone had any thoughts on what preset I should use for it. I have the edrumin8 and for starters at least am going to hook everything up to Logic Pro to trigger their Drum Kit Designer plugin. (Any pointers on setting that up as there's no map for Logic would be great too) I imagine it would be a starting point and I'll need to fine tune all the parameters? Brand. New. to all things edrums. I appreciate the guidance from all the seasoned pros here.
AZeravica
Re: Preset recommendation for Lemon 13” x 5” Mesh Black Sparkle Snare for Roland
Post by AZeravica »
Bumping this, as I’m looking for an answer too!
I think you best bet is to just roll your own. It's pretty east to adjust the settings. Here's a good starting point.
https://www.youtube.com/watch?v=v9_w32TWKZ0
