Sending CC in batches
Pim
Post by Pim »
Hi again,
Is it possible with the eDRUMin 10 to send 2 or more CC values in batches?
For example, can I send CC30 value 1 and CC30 value 2 by hitting a pad or pressing a footswitch once?
Or could I send CC29 value 10 with the first hit of a pad/footswitch and send CC35 value 51 by hitting it a second time? (So the CC messages will be sent in batches of 1 action per hit/press).
Best regards,
Pim
Re: Sending CC in batches
No.
Pim
Post by Pim »
Tue Jun 13, 2023 9:16 am
No.
Thanks for the fast reply. If I connect a midi controller that can send CC messages in batches (e.g. the Disaster Area MidiBaby) to the 5-pin-MIDI-IN of the eDRUMin 10, would the eDRUMin 10 send those messages through the 5-pin-MIDI-OUT to another device?
For example, I send CC2, value 2 and value 3 on the MidiBaby to the eDRUMin 10, would both values send further to the device conncted to eDRUMin' MIDI-OUT? Or would just the first CC2, value 2 get through?
Yes
Pim
Post by Pim »
Perfect, thank you.
EDIT: I just tested it and it works perfectly. The eDRUMin is such an amazing device.
