Expression Pedals that output Control Voltage
Curbdogmusic
Post by Curbdogmusic »
Hi-
Are these types of Expression Pedals compatible with the MIDI Expression IO? My pedal is a DOD FX-17. The CV output of the pedal is adjustable from +0-5V. I currently have it set to output +0-3.3v. Thank you.
Tom
Re: Expression Pedals that output Control Voltage
I've never tested with a pedal like that. It might work. Does it use a TS or TRS connector?
