MIDI Expression Updated to Version 2
The MIDI Expression firmware and Control Application have been updated to version 2.
New Features and Improvments
  • Complete overhaul of Control Application interface.
  • Auto-Select device function.
  • Sense support for Line6 EX-1 pedal.
  • Improved Calibration.
  • Improved Expression Curve accuracy.
  • Improved Control Application efficiency on OSX.
Bug Fixes
  • INC / DEC mode wrap around bug.
  • Several Plugin version bug fixes.
Compatibility
The version 2 Control Application is only compatible with version 2 firmware and vice versa. Version 1.1.1.3 will remain available should you wish to downgrade.
pmarchione
Re: MIDI Expression Updated to Version 2
Post by pmarchione »
Hey when I download the files to update the firmware and The MidiExpreeson software. there are no file extentions? Only comes down as MIDI and ME? whats the deal?
pmarchione wrote:Hey when I download the files to update the firmware and The MidiExpreeson software. there are no file extentions? Only comes down as MIDI and ME? whats the deal?
Couldn't reproduce this? What OS / Browser are you using?
I fixed some of the html, let me know if it resolves the issue.
pmarchione
No Luck bro.
Can you try again now? I replaced the 'spaces' in the filenames to 'underscores'. That should take care of the issue.
pmarchione
That worked.
