crushes Ableton 11
SiCa
crushes Ableton 11
Post by SiCa »
Hi, MacBook Pro 2012 16gb ram, Catalina. constantly crushes Ableton (and MainStage). It works great otherwise, but not usable at the moment. Will there be any fix for that?
Re: crushes Ableton 11
I'll look into it.
djbclark
Re: Crashes MainStage
Post by djbclark »
SiCa wrote:
Mon Jul 18, 2022 3:06 am
Constantly crashes MainStage. It works great otherwise, but not usable at the moment.
How long does it take to cause a crash in DSP Trigger 1.6.2 / do you have to do anything specific? What version of MainStage? I'm running simular hardware (Mac Mini 2012) and MainStage 3.5.5, also Catalina, haven't run into this, but haven't done any marathon practice sessions yet either.
If it continues to work for me but not you, maybe try disabling power-saving features and use the MacBook on AC power, perhaps something in that domain could be causing issues.
Here is another person with a MacBook Pro and a simular issue, although in that case it only pops up in a specific configuration, using >1 pads, you might want to read it and see if you are doing the same thing: viewtopic.php?f=25&t=1266
