edrum module+edrumin on the same vst at the same time
Marell69
Post by Marell69 »
I use Cubase 12 and just thinking about that how to use my roland module and edrumin module at the same time?
My TD-1 don't have midi in so it is impossible to connect the 2 devices as one towards to the PC.
So, adding an isntrument track in cubase and set the midi input device. You can select only one device so it is impossible too.
Maybe this midi channel 1-8 or something (never used, only instrument track), adding both modules to the same channel and send the channels to the instrument track?
Thanks,
Marton
Re: edrum module+edrumin on the same vst at the same time
I believe on a PC, only one device is allowed at a time.
On a Mac, you can select more than one device as input, so two USB cables connected to a computer would work with a Mac.
There is a device called a MIDI merger, where two MIDI cables go into the device and only one to the PC.
There might be an app that can do that also, but I don't have that knowledge.
In Cubase you have some options.
1. Set the MIDI input of your instrument track to 'All MIDI Devices'.
2. Add an extra MIDI track and set the output of that track to your Instrument track.
Marell69
Post by Marell69 »
Thanks guys!!
