eDRUMin 1.1 BETA
Re: eDRUMin 1.1 BETA
Changes in build 10
  • Fixed an issue with updating pedal editor using mulitple eDRUMin devices.
  • Fixed an issue updating UI when using multiple eDRUMin devices.
Mylo, can you see if this resolves all your issues?
Rob wrote:Changes in build 10
Yes... both issues are fixed. Nicely done. Thank you.
Changes in build 11
  • Fixed issues when changing to and from a Roland 3-Zone Cymbal.
Changes in build 12
  • Resolved piezo / switch detection issues.
evh0u812
Post by evh0u812 »
Im loving the beta releases Rob. Youve basically made my dreams come true with allowing me to bank up or down to change snare drums and kick drums on the fly. Im now making a throwoff replacement for my snare drum to incorporate switching that will allow my to scroll through different snares without reaching for the mouse. Same with the kick drum. A two button footswitch next to the kick pedal makes changing out the kick a breeze. Now how much is the bribe to get you to increase the 4 banks to 6 or 8? :lol:
Changes in build 13
  • Positional Sensing Improvements.
  • Fixed audition notes issue with Dual Mono inputs.
  • Fixed gain display not always being updated.
vandroiy
Post by vandroiy »
On the Download Page it is build 15 already.
Will you still post infos about what has changed or not anymore since the BETA Phase seems to be over?
Yeah! Rob is coming out with more improvements that he has time to write in! :)
Build 15 has some inner working tweak, and more fine tuning of Positional Sensing.
Version 1.1 is rock solid at this point, and now I'm doing very fine tuning. I probably need to do one more build to fix a tiny positional sensing issue, and then I'll leave 1.1 as is.
Changes in build 15
Changes in build 24
  • Fixed a positional sensing issue when doing flams.
  • Doing bank changes for the currently selected input now works when Control Application is closed.
  • Fixed bank being decremented instead of incremented.
  • Fixed a false compatibility issue warning.
