Re: eDRUMin 1.3 BETA now available (old)
Yes Doug. I'm heading on a two day trip starting today. I'll spend another day when I get back to do one last bug hunting session and then I'll post the BETA again.
eDRUMin version 1.3 BETA is ready for testing (again). Please keep all discussion about this BETA in this thread. I will maintain updated links to the latest BETA version below. Feel free to share your thoughts and suggestions. You can downgrade from this version to version 1.2 without losing any of your settings.
PC
http://www.audiofront.net/eDRUMin_Contr ... .3.0.4.zip
macOS
New Features and Changes
  • New hihat mode for hihat setups that use a hihat stand, especially ones with top and bottom hats.
  • The trigger input for the the hihat controller is now set from the Pedal Editor page.
  • Added a splash sensitivity control.
  • Implemented a feature to prevent sound artifacts in SD3 when rapidly triggering the closed pedal articulation.
  • Added an option to send closed pedal note even when the hihat is closed very slowly (forum request).
  • Added an option to only send hihat position CC just before a hihat note is triggered, effectively disabling SD3's transitioning between hihat samples. (forum request).
  • UI performance optimizations.
  • Upadated Manual.
Bug Fixes since 1.2
  • Fixed an issue with crosstalk cancellation.
  • Fixed an issue importing presets.
  • Fixed device color being reset after factory reset.
  • Fixed a UI issue with second pedal input of ED10.
The manual has already been updated, however I also exported a section of about the the hihat control here.
