Wacky hi-hat using eDRUMin
TheJay
Post by TheJay »
Hello there, I'm using a Simon Go hi hat plunger and metal cymbals with bell, bow and edge.
When I reset the input I was getting hi hat and crash at the same time when pressed pedal down. I've made some progress.
It's still driving me mad, I can't get it to play property in Superior Drummer 3. I've nearly got it, except it doesn't always recognise a bit when lifting and it doesn't play a different note whether open or closed.
What can I do to fix this please?
thenewdrummer
Re: Wacky hi-hat using eDRUMin
Post by thenewdrummer »
For missing hit you can look here : viewtopic.php?f=34&t=777
Is it set to send cc to superior drummer?
Can you send us a pic of your hihat pedal settings too please.
TheJay
Post by TheJay »
Rob wrote:Can you send us a pic of your hihat pedal settings too please.
I was having the same problems on CC 4 and all other settings are from calibration.
That solid blue section tells me that the calibration is not okay. Try recalibrating.
TheJay
Post by TheJay »
Hey Rob, it doesn't change.
https://i.imgur.com/yIrBmyE.gifv
Ya something is indeed wacky. So I searched "Simon Go hi hat plunger" and came up empty. Typo perhaps?
TheJay
Post by TheJay »
Yeah, it's a Go eDrum controller.
There are many versions of that control. Which module is yours made for?
TheJay
Post by TheJay »
Dave says it's like the Roland VH-11 version. It doesn't say on the actual controller.
