Two zone snare piezo rim
Re: Two zone snare piezo rim
Your piezo has fallen off the rim or there is a wiring issues. No bug.
TheJay
Post by TheJay »
By chance I changed it to Yamaha wiring and it's working...
TheJay
Post by TheJay »
Then whilst testing, without changing settings, it stopped.
TheJay
Post by TheJay »
Okay, unplugging the jack from the drum side seems to have done the trick.
It's probably a bad cable or loose connection in the jack.
TheJay
Post by TheJay »
I have a lot of cables and the problems I have experienced haven't cared about which cable is used.
To me it looked like unplugging and replugging reset it.
Knowing Dave the connections will be indestructible.
Ok....
