Questions to Consider Before Placing an Order
Seror
Post by Seror »
Hello! I am interested in purchasing the Edrumin 8. I have this question: After configuring the pads, how many presets can I save on the Edrumin 8?
Re: Questions to Consider Before Placing an Order
The eDRUMin itself can only store one preset. However, you can store any number of device snapshots (presets) on to your computer and send them to the device using the preset manager. Additionally you can store snapshots onto a USB memory stick plugged into the USB host port on the device and switch between them using a foot switch / encoder / external program change messages.
