Expanding TD-27 with ED10?
DrumGun
Post by DrumGun »
Hello all!
I have both of the mentioned items. How do I connect them to expand my TD27 inputs? Basically, I want to add another HH Controller. I’m already using the DB25 multi -pin connection for a VH-10. Wanna use a remote hat setup with another pedal controller. Thanks!
Re: Expanding TD-27 with ED10?
You can't increase the input of inputs on the TD-27 with an eDRUMin. However, you should be able to use the eDRUMin to have duplicate HH controllers though, just keep in mind that they will be triggering the same sounds on the module. To connect them, you would run a MIDI cable from the ED10 MIDI out to the TD-27 MIDI in.
