Two zone snare piezo rim
thenewdrummer
Re: Two zone snare piezo rim
Post by thenewdrummer »
Rob wrote:Okay. Will do. Unfortunately I'm sure that after I finish the Metal 3 zone pad type, I'm going to have to add a dual zone metal pad pad type as well.
I think a lot of DIY for crash are dual zone.
Question for a neophyte like me : could the hotspot algorithm work for the hotspot on the bow?
TheJay
Post by TheJay »
By the way, my snare and left tom aren't triggering side stick/rim at all anymore.
I selected calibrate and ran the sticks over every part of the snare and rim at different velocities and that seems to have caused an issue.
Is it a coincidence or can calibration do that? How can I fix it? It works really well on the right tom, shame settings can't be copied.
To copy settings from one drum to another drum...
Save tom 1 as a user preset and then apply the preset to tom 2... except the notes.
Check the cables... always check the cables. :D
That’s all I got.
Rob will have to help otherwise. :D
How I’m calibrating now... like you I find if I hit all the pieces of the drum; head, rim and rim shot it doesn’t come out quite right.
I now just hit the head and then manually adjust everything else. I seem to get better results. I’m not sure if I take anything away from the calibration process but I find if I calibrate all of it the gain is usually too low and I have to hit the head really hard to get full velocity. I don’t preclude that I’m calibrating wrong but it works for me.
Me too, if I calibrate my pads all gains are set to very low values and can hardly hear the drums. I Just reset the input and calibrate manually.
I'll look into this for version 1.3.1.
TheJay
Post by TheJay »
I think the calibration of the heads is very good. It means more dynamic playing and hits that emulate the force required to make a loud sound on an acoustic kit.
I just wish I could fix the rim at the moment. Can anyone share an image of their settings for optimum rim on centre piezo snare?
There are no hidden values being adjusted during calibration. The velocity of rim hits are simply derived from the magnitude of the vibration on the head piezo multiplied by the xstick scaler.
TheJay
Post by TheJay »
Can you please share an image of your settings please?
I can't because I'm out. The input is set to stereo?
