Piezo polarity - What is right?
Sly
Re: Piezo polarity - What is right?
Post by Sly »
mprinz wrote:Hi Sly, hi Rob,
But ... I noticed that the polarity of the waves is different with and without mounted cone. And that was the trap that got me...
That sound normal to me. The wave is different if you apply the pressure in the middle of the piezo or on the edge. one is positive the other is negative.
Yup, it's absolutely clear. But the guys wrote something like: force applied to the top of the piezo. I thought.. without cone. :|
CapCrunch
Post by CapCrunch »
So if you just have one piezo going into edrumin10 via trs plug and then into a vst on the laptop it doesn't matter how it's connected? I'm just getting started with this and having some difficulty getting it figured out. If I have 2 piezos on a surface do I just connect , for example, one ceramic part to the tip and the other to the sleeve and the copper parts to the grounds? Thanks
Sly
Post by Sly »
sleeve = ground
CapCrunch wrote:
Tue Jun 08, 2021 11:02 pm
Sleeve = ground
so you likely mean one ceramic to tip, the other to ring, and both copper (brass in fact) to sleeve, which is right.
For eDRUMin devices, either way will work. Check the appendix in the manual for wiring diagrams.
