Hi Rob
I'm on ED8 with 2.3.2.3.1 control application, Mac Os Catalina 10.15.7. When I try to duplicate a factory preset nothing is duplicated to the user preset section. Tried uninstalling and reinstalling. Changed usb from hub to dedicated Mac Mini usb input. Duplicating trigger presets works though. Maybe I'm missing something.
Duplicate drum map preset issue
Re: Duplicate drum map preset issue
My studio is out of commission for a week or so, bit I'll look investigate this when I'm able.
