No factory presets
iainp999
No factory presets
Post by iainp999 »
Hi there,
I just received my edrumin 10 and excited to get started!
When setting up a pad in the software I noticed that there are no factory presets available to me.
Is there another step I need to take to install these?
Many thanks.
Re: No factory presets
You are using the latest version of the control application?
iainp999
Post by iainp999 »
Hi Rob, yes the latest version (2.3.1.35 2024-08-31)
iainp999
Post by iainp999 »
I figured it out, Rob.
I prefer to install my applications onto an external SSD, so I changed the install location when running the installer.
Installing to the default drive on my mac has resolved this.
Thanks for replying to me, thought I'd update in case others come across this.
Might be something I can fix in the future. I'll make a note to look into it.
