eDRUMin 1.2 BETA is now available
mrantarctica
Re: eDRUMin 1.2 BETA is now available
Post by mrantarctica »
Retro Rambler wrote:Rob thank you for the continued work on this beta.
I think my previous message(s) here probably disappeared with the rest on my old account but for posterity or whatever - thank you for bumping the max gain up to 12 the beta. It did help with my Diamond Electronic Drums trigger.
Will post a few more details to end that other thread but I won't be needing that gain bump anymore. :)
Retro I'm curious to know how you feel about the performance of your setup. Are you satisfied with latency and performance? How does the setup compare with and without your RME card?
Sorry for hijacking thread but there is no PM function
Impulseblue06gto
Post by Impulseblue06gto »
Enjoying this beta turning up the gain made my tom almost trigger identical to the rest of my Roland kit prior it was alittle bit off but now it's about spot on with the feel moved it from 7 to 10 with the gain in my case with a pdx 6 pad
It's actually no longer in BETA. Unfortunately, there are some significant bugs I discovered.
1. xTalk cancellation was accidently disabled.
2. For ED10, the second hihat input doesn't show movement in the UI.
Version 1.3 is right around the corner. Hopefully it'll be available by the weekend. Version 1.3 is all about the hihat pedal inputs:
1. Added a wew method of detecting closed hihat articulation for hihat controllers on hihat stands.
2. Splash sensitivity control (as requested in the forums).
3. Ability to effectively disable SD3 transmutation of hihat sounds by only sending hihat position CC when the hihat cymbal is triggered (as requested in the forums).
4. Ability to mute an open ringing hihat sound when fully pressing down on the hihat pedal slowly (by sending the lowest velocity closed pedal note).
Looking forward to testing these hi-hat innovations in 1.3
