eDRUMin 2.4 BETA
Re: eDRUMin 2.4 BETA
I posted build 10. No changes to firmware.
  • Updated several presets.
  • Fixed issue loading a pedal preset save on ED4/10 and loaded on ED8/ED12 and vice versa.
  • Fixed linux version hanging if ED12 is connected.
mrmbira
Post by mrmbira »
the links aren't working
Thanks. Should be working now.
mrmbira
Post by mrmbira »
windows link worked but the others say version 9 still.
CodaClef
Post by CodaClef »
Tue May 06, 2025 10:31 am
When you say updated presets, do they need to be re-applied to get them or do they auto update on inputs they are assigned to?
It just means I've updated some of the factory presets that are stored on your computer. If you wanted to send some of the presets to your device, you would need to use the Preset Manager to send them. Here's an excerpt from the manual that should help you understand presets.
eDRUMin devices only have one set of settings. Whenever you are making changes using the Control Application, you are making changes to those settings on the device.
However, using the Preset Manager, you can download the device’s settings and save them to your computer. Likewise you can use the Preset Manager to send saved settings from your computer back to the device. However, it’s important to remember that whenever you are adjusting controls in the Control Applications, you are always editing the settings on the device and not the settings saved on your computer and in order to update the settings saved on your computer, you would load a preset, make changes with the control application, and then overwrite the preset again.
I bought an M4 Mac Mini to replace my ridiculously slow 2018 i3 Mac Mini. I hate buying things I don't need, but I wasn't able to update to Sequoia due to intermittent kernel panics and finally had to buy a new machine just so I could submit the iOS Control Application. I can't say I'm sad. The M4 mini is at least 10x faster--can't believe I waited this long. If anyone wants to test version 2.4 on iOS, email me your appleID to support at audiofront dot net and I'll add you to TestFlight.
This also means that in the near future I'll be dropping support for some older versions of OSX. I think currently I support all the way back to Lion.
