eDRUMin 1.6 BETA
Re: eDRUMin 1.6 BETA
dsteinschneider wrote:
Sun Aug 08, 2021 6:52 pm
I turned on positional sensing for them but haven't spent time configuring that on the Superior Drummer side
Does the positional sensing on the eDRUMin side seem to track the position?
Sun Aug 08, 2021 5:15 am
Thanks. I'll fix it for the next build.
Not to harp on small display bugs. I noticed that an USB Host output yellow indicator illuminates even when nothing is connected. At least for me it was the empty slot after the last used slot (so ED4, TD-17, empty, and empty…the first empty output would illuminate).
Edit: the extra output lights are only when there is an input from a connected device, and it is the 2nd and 3rd output light. So triggering pad on the ED10 host is not an issue. However, I only had ED4 connected and I trigger a pad one ED4, empty slots 2 and 3 out light illuminate. I turned on TD-17 to fill in the 2nd slot. Self was off. There was no output light on TD-17 when expected. However the third light would illuminate even though empty.
Thanks, I'm not seeing the issue here so I must have already fixed it.
Dadwrshpdrum wrote:
Mon Aug 09, 2021 3:33 am
Found and fixed for the next build.
Changes in Build 4
  • Fixed an issue where ED10 might try to send MIDI to a device that wasn't connected.
  • Fixed several small display issues in External MIDI page.
  • Improved pedal sense support ATV H14 and other externally powered hihat designs.
  • Fixed positional type indicator not disappearing when viewing a pad that doesn't support positional sensing.
https://www.audiofront.net/eDRUMin_Cont ... .6.0.4.zip
Mon Aug 09, 2021 9:08 am
Yes, the various things I reported appear fixed. Thanks!
Edit: the little number for positional sensing appears fixed for mono inputs, but remains latched for stereo inputs.
Also it appears even though positional sensing is on (for my ride) and the semi-circle appears to be working. The note (I can’t test CC) is not being sent. I did notice as well when I did the update my settings switched from Note to CC. When I went back to Note the positional sensing note never illuminates (even though the semi-circle appears to be doing its thing).
Dadwrshpdrum wrote:
Mon Aug 09, 2021 1:06 pm
So I downgraded to build 3 and confirmed that positional sensing on the ride worked as expected. When I upgraded to latest I noticed the first time I played the ride it looked like the positional sensing note illuminated, but once I hit the bell or did other things. Nothing more. No longer would illuminate. And EZD2 was no longer showing a change in MIDI note as I played across the bow.
It's a software related bug. No firmware updated needed to fix the issue. I'll post a new update shortly.
Fixed! Again not to harp :? but the 1/2 numbers are still latched for stereo inputs it looks like. I have a couple Toms split and the numbers are not there. Same thing for a mono input for my kick (not split just set to mono). No numbers, but the stereo inputs with no positional sensing has a number latched still.
