eDRUMin 1.6 BETA
Re: eDRUMin 1.6 BETA
I don’t have one but I could ask Mike from drone
Rob here is a video of what I’m seeing with adjusting the Hold.
https://youtu.be/MEnkCid3h38
I start out adjusting the Hold. Let it auto save. I then jump around a few pads and then come back to the pad I adjusted and you can see the Hold is not where I left it.
All inputs are displaying the same issue. At first I thought it was decreasing by the same amount of 0.7 but it turns out the decrease amount is random.
I don’t know if this is a display issue or if the eDRUMin is actually reporting that value for my Hold.
Ya, that's the scan controls not updating properly. I think I already fixed it for the macOS build, but not the Windows one. I'll fix it for build 2. If you change inputs and the resize the UI, you should see the controls update properly.
Btw, let me know if the positional sensing works on your ATV cymbals now? I'm guessing it might work with the Roland positional sensing algorithm.
Dadwrshpdrum wrote:
Fri Aug 06, 2021 4:22 am
A possible bug:
Set up: ED4, TD-17 and Alesis Strike Multipad connected to a powered hub connected to ED10 USB host port. Local control off on TD-17 and Multipad.
When I select “self” and there are no more devices connected in the list then “self” is selected for all of the empty slots. Very minor display bug.
More detail. With the TD-17 and ED4 on hub then when I select self on TD-17 three “self” buttons showed selected and ED4 grayed out. With TD-17, ED4 and multipad on the hub then when I select the first self option (eg multipad) that is selected and only that. When I select TD-17 then the final empty slot shows selected as well.
Thanks. This should be fixed in the next build.
Fri Aug 06, 2021 11:09 am
If you have a multimeter, I would like to know what voltage there is between the tip and ground of the cable when the drone hihat is powered, but not connected to the eDRUMin. That would allow me to do some tests here to see if there's a workaround.
I have asked Mike about this but still waiting for a reply from him. Meanwhile I have confirmed it now, one needs to unplug the pedal cable before plugging the edrumin, and then plug it again, I said before that the pedal was reset but that was not the case, the pedal keeps its settings, one needs just to press the hihat pedal and depress it a couple of times and the edrum in detects it again perfectly.
Changes in Build 2
  • More Bell Sense improvements.
  • Fixed the ride note assignments for the Addictive Drums map.
  • Disabled and turned off 'self' switches on External MIDI page for unconnected devices.
https://www.audiofront.net/eDRUMin_Cont ... .6.0.2.zip
great, the bell area in the cy-15 bow has been reduced now to about 2-3 lines from the bell, but unless you hit it exactly there, which hasn’t happen by my normal playing, it triggers now the bow perfectly, thanks!
Yep, that bow bell triggering area is getting smaller, I think that’s good enough man, enjoy your weekend
