Hi
Just wondering if you can use the expression quattro connected to a synthesizer with USB midi for live use.
Expression quattro connected to synth with USB
Re: Expression quattro connected to synth with USB
Most synths don't have a USB host port, so the answer is probably no. Some high end ones do, though. Most people would need a MIDI Expression iO and connect the two together using MIDI cables.
