Shipping times?
cmosco
Shipping times?
Post by cmosco »
Can anyone here tell me where this company is located and approximate shipping times to locations in the continental US?
(assuming the item is in stock, of course)
Thanks for any info.
Re: Shipping times?
Shipping is from Taiwan, which is where I'm based. Shipping depends on the shipping method. Just put an item in your cart and start the order process and you'll see the estimated shipping times for your location.
cmosco
Re: Shipping times?
Post by cmosco »
Thank you for the reply.
With the standard method, do you find the 14 day estimate to be fairly accurate? Within a couple of days, at least?
I see the iO model has the 9v input, but does it have the option of bus power as well?
Also, is there any feature the Quatro has that is not included in the iO?
Re: Shipping times?
I would say delivery times are roughly +/- 5 days, but nothing is certain.
The iO is typically bus powered, but the 9V connector is there in case you need to use the unit without a USB connection.
