Setting up DSP in Presonus Studio One
I have downloaded the Free program and moved the .dll file to the VST folder Studio One uses for plugins. I do not see it as an effect. I would like to do testing before getting the full version.
Re: Setting up DSP in Presonus Studio One
After some experimenting, I got the program to work!! Very easy once I figured it out. Bought full version. Was triggering drum sounds from my sons guitar! Extremely functional. Will try it live this weekend.
It works great in Presonus Studio One.
What's *very* nice is: In Studio One, you can insert Vst FX directly into the Audio Input channels. So you don't need separate channels! One track for the drum sampler (rumpler?
) is enough. I don't know of any sequencer that let's you do this (if someone knows: please let me know).
Tip: click on the mixer pane's "Vertical-Big size" button to make the FX slots visible.
I use the combination Presonus Studio One 2 , BFD2 with John Scott (Platinum Samples) , and DSP Trigger. All on 64 bit.
Cheers, T
Cheers, T
