Seek a Yamaha RHH 135 Hi-Hat Preset
Forum rules
marcus110477
Post by marcus110477 »
Hi everyone,
Have anyone a Preset or the Settings for the Yamaha RHH 135 Hi-Hat?
thanks a lot
Greetz
Marcus
gdunlop
Re: Seek a Yamaha RHH 135 Hi-Hat Preset
Post by gdunlop »
Images show the settings I use with an RHH 135 triggering SD3. Pedal sense is disabled. I grabbed a screenshot while I was using the pedal, and you can clearly see the four fixed levels produced by the sensor. This works but I don't get the full capabilities of SD3 so I am upgrading.
I have the cymbal set-up as a Yamaha 3-zone. Not sure why as the RHH 135 cymbal is only 2-zone but it works fine.
Hope that helps.
