FR: Dual mode hold time - user definable?
ericzang
Post by ericzang »
Hi, in an update, I think it would be quite helpful if the Dual Mode hold time could be user definable, or at least a choice between short, medium, or long.
In my particular use case: short press toggles the input to a looper, long press clears the loop. Currently the hold time is short enough that the loop often will clear accidentally when actually the desired behavior is to toggle the input.
Thanks!
Re: FR: Dual mode hold time - user definable?
I'll look into it. I have to see if there's any room left in the memory structures to support it.
