Yamaha KU100
inzieye
Yamaha KU100
Post by inzieye »
is it possible to use Yamaha KU100 pedal with MDI Expression I/O please?
If yes, how can I configure it for kick drum with velocity?
Thank you.
All the best
Re: Yamaha KU100
I'm not familiar with that pedal. If it's piezo based, then it won't work with.a MIDI Expression. Do you have both already? What happens when you plug it in?
inzieye
Re: Yamaha KU100
Post by inzieye »
Thank you for your answer.
when I plug it, I'm only able to have a Note but not the velocity. I've tried every mode in MIDI expression app. Maybe it is piezo based. I think I will buy a Hi-hat pedal for kick (I've one HH-65 but I need another one (Hi-hat AND Kick)).
