Midi Expression with M-audio expression pedal
Itayak
Post by Itayak »
Hi friends
Do you know if Midi Expression will work with M-audio expression pedal, and if so will it be able to send 0-100 value?
I have 3 M- audio expression pedal I'd like to use at the same midi channel, will it be possible?
Unfortunately with Roland fc 300, my M-audio pedals send 40-100 value.. :?
Thanks in advance
Itay
Re: Midi Expression with M-audio expression pedal
Yes, that pedal is supported, and the range of values it sends can be customized to your liking.
Itayak
Post by Itayak »
Thanks Rob
