Low end piezo/piezo or piezo/piezo/piezo edrum snares?
djbclark
Post by djbclark »
Anyone know of any electronic snare pads with a rimshot 2 zone or rimshot and cross stick 3 zone configuration using only piezos, and thus likely to be able to work with DSP Trigger?
Under $100 used would be preferable.
djbclark
Re: Low end piezo/piezo or piezo/piezo/piezo edrum snares?
Post by djbclark »
Couldn't find any piezo/piezo/piezo edrums other than maybe some very high-end Roland stuff, but Alesis has piezo/piezo dual zone drums that DSP Trigger can detect rimshots on with ease for reasonable prices, eg new $70ish / used $40ish:
Alesis Command 8 inch Mesh Drum Pad with Clamp and Silverline Audio 10ft Trigger Cable Bundle [Compatible with Roland/Yamaha/Simmons/Ion]
https://www.amazon.com/gp/product/B09PFH4MBV
