DSP Trigger w/ RT30HR and RT30K
AndreaZanini
Contact:
Post by AndreaZanini »
Has anyone tried it with these Triggers?
I have a full acoustic kit and would be using DSP Trigger to reinforce Snare and Kick only for studio recording.
Thank you!
PS I have read that Rob is not currently working on DSP Trigger as his time is fully taken by Edrumin and Expression. But is it temporaryor is DSP Trigger being dropped?
____
Andy
Re: DSP Trigger w/ RT30HR and RT30K
It's not being dropped, it's just not being developed. If bugs are found I will fix them, but at the moment I have no plans to add new features.
AndreaZanini
Contact:
Thank you Rob. Makes sense. So will I be able to use the above-mentioned triggers? :)
____
Andy
Should work.
But keep in mind that if you are using using stereo trigger, you will need to split it into two mono connections to get it into your audio interface.
AndreaZanini
Contact:
Thank you Rob. Will definitely keep this in mind for the channel count on the interface!
____
Andy
