DSP Trigger and Logic Pro X
damill
Post by damill »
I've downloaded the trial version but cannot get it to work with Logic Pro 10.6.1. Is there a compatibility issue? Any help would be greatly appreciated.
Re: DSP Trigger and Logic Pro X
Shouldn't be an issue. I'll test and get back to you.
damill
Post by damill »
I restarted the computer. It shows up. I see set up instructions for sonar and Cubase. Do you have any for logic?
Thanks
Rabidreject
Post by Rabidreject »
Yeah, I was actually wanting to ask the same thing…well, I did ask the same thing but it was ina thread nobody is reading.
I can’t figure it out. I did just read the MainStage instructions and the only thing it said that I didn’t do was to simply click on the pad display in logic. I did everything else it said and nada. Well at points almost seemed like a microphone. I was tapping it and a tapping sound came out the speakers. I think I was in an audio track by accident tho. It’s not massively urgent as I do have a edrumin device coming but I’m just a little confused why it won’t pickup my snare that’s plugged directly in to my focusrite scarlette.
